boji
Thanks Ian for the link about grounding!
"Outside the modules, power and ground were distributed using large copper or brass bus bars. Each module was locally decoupled with 1000uF. Buses were carried in a special extrusion that consisted of a number of U shaped channels, one for each bus. Each module was hand wired to the bus via a bus resistor inserted in a feed through in the extrusion. "
"The only way to minimise interaction between modules is to make sure the power and ground conductors are as close to zero resistance as possible."
I'm not sure I understand the reason for the bus bar resistors. Wouldn't omitting them achieve the least resistance? Are the resistors a necessary evil for channel isolation?
Edit: Now that I think of it this is a B+ issue, isn't it.
