Mk012 increased current.
Seeker
Orlando, Fl
I’m building a few large diaphragm mics with a mk012 circuit…. I got to wondering if ther would be any benefit / harm in changing the 13k resistors to something like 2k2 to give the transistors as much current as is available…
Thanks for you thoughts!
That would "help" reduce the voltage available for biasing the capsule, leading to WORSE signal-to-noise ratio.
