Hi Andreas, So the -125V and -5.8V on the board read as they should...actually the -125V was more like -120V...but I did use an analog meter, so...However, still no voltage reading off 7 pin. This unit is relatively new to me and I hadn't even listened to the mic through this PSU yet. So with getting no reading on pin 7, I plugged in the PSU to a preamp to do a listening test and see if the pattern knob had any affect. Low and behold, turning the pattern knob did NOT affect the mics pickup behavior. Then to rule out the potential of the mic itself being the source of the issue, I plugged in my other K2 and the result was the same. So..it's starting too look like my amateurish understanding of electronics may not be the biggest problem with this PSU! (-;.
