[quote author="buttachunk"]... your attentuators are the problem.
they are 10k attentuators, and 600 ohms is the average nominal impedence of the boxes you have. [/quote]
Looking at the web site and the PDF from the web site I can't find that info ?
Model BM15A
System 2-way Active Nearfield Monitor
Frequency Response
(+/- 3 dB) 30 Hz - 21 kHz
Max SPL 1m, pair(IEC Long Term) 124 dB RMS
Max SPL 2m, 5.1(IEC Long Term) 125,5 dB RMS
Input level for 85 dB SPL @ 1m (+4/-10) -18 dBu RMS / -34 dBu RMS
Input level for max peak SPL (+4/-10) +16 dBu peak / -1 dBu peak
Power consumption Idle: 40 W / Max: 300 W
Amplifier power Tweeter: 100 W / Woofer: 200 W
Resonance Frequency 39 Hz
Internal Cabinet Volume 27,5 liters
Bass Principle Bass reflex
Crossover Frequencies 1800 Hz
Crossover Slope 30 dB/oct
Tweeter Esotec 28 mm soft dome, rear chamber, Magnetic fluid. 4 mm die-cast alu front,
Woofer 24 cm, One-piece molded polypropylene cone, 100 mm pure alu wire voice coil
Weight 18,6 kg
Dimensions (WxHxL) 290 x 454 x 388 mm
ooo
5th order x-over ... never made one of them before ??? did make one 6th order for something but generally never more the 4th.
.... and from the PDF file,
Instrumentation type
electronically balanced
input stage
I find it a little surprising that it is 600 ohms input. It also offers the -10 input with -1 dBu to peak it out. This too is 600 ohms ???
I think I would be tempted to go with an unbalanced approach considering the functions you are trying to achieve.
Can we confirm that it is 600 ohms ?
