It's been a banner week here between the noisy Altec and now-silent Lang. So...on to the Scully. Awhile ago, a friend of mine dumped a Scully 280 head amp into my lap and asked me to take a look at it for use as a mic pre, since that's a thing now. "High noise floor," said the attached note.
Previous owner had attached a guitar pedal-style 2.1 coax barrel cable to the power terminals on the Amphenol connector, so I whipped up a regulated -24V power supply (with a 7924) in a Hammond box with an output jack to mate with the barrel connector. Not the best connector, for sure. All internal voltages measure where they should, FWIW.
So here's what it does: "PSSSSHHHHHHHHHH" on mic input as you turn up record level. Passes sound, amplifies mic. At about 7 or so on the dial, it starts oscillating. Audible frequency range.
Here's where it gets fun: tapping unit, shaking it, thumping it changes the oscillation. With the proper "technical thump" oscillation goes away! PSSSSHHHHHHHHH is still there, though.
So where should I look first? One thing that sucks about these is that the playback and record cards are in a a spot-welded subframe that CANNOT be opened, making probing specific areas of each card to locate the noise source next to impossible without a card extender.
Other facts:
- all components, including electrolytics, are original.
- putting the mode switch into playback mode reduces noise dramatically, making me think the mic pre/record card is the problem.
I have a VERY small supply of otherwise unobtainable transistors; certainly not enough to replace all of them. I might be able to replace everything on the input card.
Any thoughts? Run and hide? Kill it with fire?
While I would at this point prefer the latter, it's not mine, it's my friend's.
Other facts:
