Mbira
I am working on two different old tube amps. One is a perty old Vega. It runs one 6L6 and a couple of preamp tubes. This is one of those that has the output transformer connected to the speaker, so I can't really test it with a power resistor. When I first powered it up it gave this aweful humming sound (bad caps-I think). So I replaced the power caps. The only caps I didn't replace were a couple of the 600v .01uF caps. Now the amp doesn't have the hum, but the output seems very low to me. It was using an old on-off volume knob combo that went right from the input to the knob to the grid. It said 500M (?!?) on it. It was unable to turn, so I replaced it. I measured it and came up with 500K linear for a value. I have never seen a 500M put before (would this be common?)
Now I have very low output. This amp has three input jacks and only one of them are connected to the pot. The other two go in parallel straight into the grid.
I guess my question is
1) How much output "should" I expect from one 6L6? (18ish watts?)
2) Would not replacing those 600v .01uF affect the output?
This is already long enough, so I'll post the other question in another thread.
