Moseley Associates TFL-280B Audio Limiter
It's a smash-o-matic! Or, "tough luck 280" as we used to call it back in the day.
It's an interesting box, using a diode string variolosser as variable attenuator (like the audimax/volumax twins), high speed, high current circuitry for the side chain, a control voltage ripple reducing circuit, and just for kicks, it's normally set up to clip the gain amp on peaks to set an absolute ceiling.
When I used it in a broadcast setting, it really limited hard. Problem was, it was tough to get any "soul" out of it. It just smashed the audio.
If it doesn't go for too much, it might be fun to play with. I have a modified (by someone else :roll: ) unit sitting under my bench at work, in the hopes of reviving it and finding a use for it.
Hello Chaps,
Just wondering if any of you kind fellows, have a schematic / service manual for the TFL-280B ?
I got one, and its gone a little funny over the last month !!!
Regards,
Steve :)
Kid Squid said:
Hello Chaps,
Regards,
Steve :)
Hey, Steve,
I've got one somewhere, but don't know where. Moved within  the last 5 months and still unpacking books, manuals etc. I'll keep an eye out, but no promises on a quick find  ;D
Kid Squid said:
Hiya Chaps,
JD, did you ever find the Moseley TFL-280 manuals ? I'd still love to get a copy from you  :)
Hope you had a good Christmas and New year !!!!
Kindest Regards,
Steve
Hey Steve!
Hope you had a Merry and a Happy also.
Believe it or not, since that last post I've moved, again! I've slowly been getting my shop together and I'm reaching  the boxes with all of my manuals...with any luck I'll stumble upon it..
Regards,
John
Kid Squid said:
Hi John,
Just a little reminder if you get a chance  ;)
No worries, 'cause I had forgot about it totally !
Steve
Steve,
Weird coincidence; Going through some boxes in my garage last weekend....BINGO!
I found the TFL-280 manual! (cue Twilite Zone music theme).
The only issue is the schematics are really huge fold out sheets. I'm going to try and reduce them, or sectionlize them at work. Once I've got it all manageable, I'll create a .pdf, and send it to you.
I'll get in touch when I'm done.
John
A long time comming, but here 'tis!!
Unfortunately, the manual is to big to attach here, but the schema's should get you started.
Enjoy. I've worked a fair amount with this peice, though many years ago, so if you have questions, let me know!
  • Moseley TFL-280 Schematics.pdf
    244.6 KB
