I am by no means an expert on motor run caps, but I am sure the 1,5uF will do the job pretty good. Think of the tolerances in the past and all the old MP capacitors that are still doing their job even though their capacity has doubled. This will work.
Edit:
Wikipedia says that the following happens if the capacitor is incorrectly dimensioned. I still think you are close enough:
"If a wrong capacitance value is installed, it will cause an uneven magnetic field around the rotor. This causes the rotor to hesitate at the uneven spots, resulting in irregular rotation, especially under load. This hesitation can cause the motor to become noisy, increase energy consumption, cause performance to drop and the motor to overheat"
