kosty
Hey guys !
I am trying to fix a MOTU 2408 mk3 that has been powered on with 230V while switched to 110V.
The device wasn't powering up so I opened the lid to check for blown fuses or other components.
There was no burn marks on the PCB (top and bottom side) or no blown capacitors or resistors after visual inspection.
I deduced that the power transformer might have taken damage since the fuse was still good.
I reassembled the device and gave it one more try. You never know....
Luckily and I really have no idea why, but the device powered on and seemed to work !
I left the top lid open and the interface powered on to see if anything started burning.
After 5 min the large1500uF cap exploded. I guess thats because of overvoltage.
edit: It's a 15000uF / 10V cap.
My questions to you now :
- Is it possible that the cap was already damaged when the device was powered with the wrong voltage and only exploded now because of it's precondition ? In that case I can try to replace the cap.
- Can the transformer be damaged when fed with wrong voltage ?
- Why didn't the slow blow 250 mA fuse blow ?
Hope you can give me some assistance
Thanks !
Thanks !
