The 1:0.707 ratio preserves impedances.
This is usually not critical. But German Engineers do it right. At any moment, at any point in this 250 ohm system, they can substitute a different 250 ohm item and get THE expected result.
Overload should not be an issue at mike level. Noise can be. Noise with Neumann mikes is not a serious issue.
If you study "600 match" MS stuff with 1:1 ratios, it is often worked as 600:1200 or so.
> you get 6dB boost.
+6dB voltage, -6dB current.
With zero-Z source and hi-Z load (current is not sucked), then impedance is not critical. 1:1 iron is readily available.
> you get 6dB boost.
In a non-match system, easy to pot-down. Here, or further along the chain. One of the main features of M/S -is- that you can pot-up/down the M and the S as needed.
> a coefficient of 0.5 is safe, 0.7 hazardous, and 1:1 a disaster.
Right. 1+1=2, so two tracks at 99% can make a peak at 198%.
In a nearly random signal (spaced pair), 99%+99% will rarely happen. Possibly not even once per track, and then so briefly that nobody will notice.
In a panpot "stereo" passage where one mike is very dominant, you WILL get 90%+90%= 180%, constant 5dB clipping. If the mix-image engineer drops to pure mono, 6dB. So as Jonte says, You have to have "divide by two" somewhere. For more typical pop-stereo, you might use 4dB and nobody notices the rare 1dB-2dB clip.
> it can't be THIS easy . . . just 4 resistors?
Yes, but:
As mentioned, some port(s) MUST be fully floating. (Not Forced-Balanced.) As drawn, only the S source must float, which is elegant. (However in practice this may upset M-S identity, running S as full-float and M as unbalanced.)
It also directly accounts for "divide by two" somewhere, by throwing-away half your Power. This is acceptable at Line level, may be fine at Neumann level, would be very distresssing at ribbon level.
And if you must add a transformer to gain "fully floating", then you can go ahead and do it with no resistors, just summing powers with series windings. M and S are handled identically, no oddities to the image.
> you get 6dB boost.
> you get 6dB boost.
Yes, but:
