digitall2000
hi thanks for any help in advance
i have tried to scour the existing mtr90 pages but not getting the answers i need
i've maintained other multi-tracks but that was a while ago but am not familiar at all with this machine
trying to help a friend with "tape transport troubles" as he said
to find out today that the machine acted oddly, was shut down, then has been sitting idle for about two years
well last night the machine would only rewind, try to put in stop would bring it to a crawl in reverse
then it would speed up again in reverse until the came off the take-up reel flapping about wildly on the supply wheel
also at this point it seems to be stuck in cue mode (no tape lifters). the tape tension on either sides of the heads seem to be different as per the position of the tension arms and the machine when in reverse sounds like there is too much on the tape.
if the machine stays in the crawling stall mode (stop mode) it blows the 40v breaker on the psu
took out the capstan servo motor and have both the sine and square wave at the appropriate test points when turning
the capstan by hand so at that point the instructions say initialize the reel servos and "put the machine into Play mode"
and there i am the machine "wont go into play mode"
a few questions to those that may know
1. anything come to mind that wont let the machine go int play mode?
2. what drives the capstan servodisk motor --- sine wave, square wave, and what amplitude?
3. what could i use to check the capstan servodisk motor just to see if it functions?
so tried today with pretty much the same results. decide to pack it in for the day and on the last rewind the machine is
rewinding at a constant rate instead of speeding up, the tape lifters activate and no odd sound of stretchy tape, as the
tape come close to the end of the rewind it slows down and comes of the take up reel nice and easy like (that's a first)
thanks
lance
thanks
lance
