Hi ,
I have a few reverb tanks lying around here ,3 long ,2 short .
Id like to make up a stereo spring setup, Im thinking of making a driver a bit like the fender standalone reverb ,transformer coupled 6v6 ,maybe useing a champ style 10 watt transformer .These transformers have several taps on the secondary ,so should be easily able to drive at least two 8 ohm tanks . Ive rewired the outputs from the tanks to TRS jack ,so they can feed a balanced mic input ,this reduces any hum picked up from the output coil and is a fairly good match for the 2250 ohm transducers .
What I really fancy trying is M\S stereo sum difference arrangement on the tank outputs but no one seems to have tried this before ,If anyone out there has any ideas on how to go about doing this any info would be greatly appriciated .
Multiple tanks definately give a smoother reverb ,less like a spring and more of a plate reverb type sound ,the clangyness of the single spring arrangement disappears when multiple tanks are combined ,Mesa have dual tanks in one or two of their higher end preamps ,and a company called Paia do a hot springs kit which also uses two tanks .
All comments /criticisms welcome
