Goodizzy
Active member
Good evening,
I love this website. I've been lurking longer than I care to admit and have learned a lot from the many useful posts.
I am now embarking on creating a very small valve mixer based off the REDD.47. I am hoping to mount this in a spare 19" audio rack I have laying around. I intend to mount te actual line amps themselves in a repurposed military surplus signal generator rack unit. The chassis is already drilled to accomodate 11 octal-sized valves and I would like to adapt this to housing 2-4 of these line amps.
I have an older 4-channel valve Vortexion mixer as well that was designed for the broadcast industry. Underneath the chassis there are very small, (approx 1.5" high by x 3.5" long) dividing walls which separate the valve sockets. I'm unsure what they are made of, but no doubt something non-ferrous.
My question is- should I incorporate these, or something similar, into the line amps' chassis? Besides proper line dressing, is there anything else that should be done to shield the REDD.47's sensititive EF86 input stage? I know the originals were houses in cassettes but they seem to have been sandwiched together fairly closely without apparent crosstalk or interference.
I'd appreciate any insight or suggestions. Thanks!
