That would be rejecting the unique sonic character of this amp in favour of another, which may be great for you, but not for others (at least not for me). I'm not sure now, but Albert Lee used to swear by his MM amp. The list of famous users is quite long.fazer said:If that were my amp, I would yank that board and put a dumble OD board set in there. Make it all tube and retire with 1 amp that can be tweaked and worked on for as long as there are tubes.
Way more fun and very well documented. Dumble did it with several MM amps.
http://www.pacair.com/discus/messages/75/75.html
The big issue there is that these amps are not popular, because they are heavy (BIG transformers) and too loud (beaucoup Watts), so people tend to let them go for a pittance; as a result, they are in favour with tweakers. That's exactly what happened with Princetons, when they lost favour because they were too small and underpowered (which shows that different causes can have same effects) when big amps (Sunn, Kustom) became the fashion du jour. People got rid of them and Howard D. bought them as donours.
