output circuit,
grids are held constant, modulation by way of the cathodes,
has lots of oscillation caps, clipped them out but might put them back in,
(500 pf on sec legs)
getting some not so nice crunch noise at certain gain/vol settings,
OPT could be the culprit but caps are easier than a rewind,
718 volts on the plate at the high setting!
keep your arms and legs inside the bus while it is moving, ;D
note grounded suppressor grids sit lower than cathodes
hi/lo voltages:
plate - 478/718
screen - 236/357
grid - 24/24
cathode - 45/58
if you subtract cathode offset you only have 718-58= 660 on the plates,
problem was somebody had the speaker plugged into the ext jack,
