joulupukki
Nope. I emailed today and he quickly said that they don't sell it outside of their own kits unfortunately.Matt will likely sell the transformer separately, if you email him.
You’re right about C2. I removed it in one of the DIY mics and now it’s definitely got more gain (a little more than the MP now at the same preamp level). It doesn’t seem to have adverse effects that I can tell. The THD didn’t really change relative to the new amount of gain. I was a little bit aggressive getting C2 out and one leg of it broke and cracked the tiny cap … so I won’t be putting it back in and will probably remove C2 from the other DIY mic as well.I would put my bet on the removal of C2, which increased the gain, but also increases THD. Transformer distortion is mainly below 1kHz, THD increase of the JFET across the whole audio bandwidth. It's mainly 2nd order, tube like distortion, which in moderate amounts may sound benign and give a sense of clarity and detail if the fundamental frequency is in the mid range.
Gotcha. That’s kind of what I figured after reading more about it this morning. My guess at this point is that it’s just a sum of all the parts (capsule, JFET, caps, and TX) that’s contributing to the subtle differences between the two mics. It could also be the vents on the mic bodies & capsules as well … in addition to the difference in space between the nose cone and capsule. Probably not enough to worry about.The other caps you mentioned will only affect gain and noise in the lowest octave(s) if they were chosen too small.
I’m not 100% sure yet whether I’ll be able to get into the studio or potentially borrow/rent their real KM84. If I do, I know I’ll try guitar and/or whatever else they’ve got there … within reason. Is there any particular sound source you’d be interested in hearing the difference on?Would be awesome if you could share some of the shootouts with the KM84 and your DIY mics! Are you also going to make recordings of instruments other than guitar?
Thanks!Nice song, nice playing!
Dang. My right ear can definitely hear higher frequencies than my left so I definitely partially understand that!I couldn't tell one from the other. But I have to admit, I have great difficulty hearing subtle differences. Especially in the top end, because my ears are perfect 9.5 kHz Low-Pass filters. So if anyone else hears differences, I would be the last one to deny that.
Good points! Hopefully I'll get a chance to try out a real KM-84. In the meantime I'll have to go visit someone with a drum set and see how these to. With C2 missing they're definitely not going to be able to handle a high SPL. I know MP offers this same build optimized for snare drumps and has a higher-value C2 cap, a different transformer, and a different value for C4 as well.If there are any audible differences between the KM84 and your mics, I would expect them to hear in the lower and higher octaves, especially on loud instruments. So if you are curious about it yourself and have the opportunity, I would say: any bass instrument, toms, snares, overheads on drums, violin, etc. Like someone else already said, guitar and voice are mainly in the mid octaves and not very loud, so differences due to non-linear distortions will be less noticeable than in the extremes of the audio range.
The lower octaves, say below 100 Hz, could sound different because then the transformer might saturate and start to distort heavily. And they all have different transformers. The higher octaves, say above 6kHz, when played loud, will produce Difference Frequency Distortion and Intermodulation Distortion in the mid and lower octaves. Due to the masking effect, the THD of the higher octaves will hardly be noticeable, but the DFD/IMD tones will end up in the sensitive 1kHz-6kHz region and may cause harshness. I would expect this to be more noticeable with your MP and DIY mics without C2 and less so with the KM84. I would not consider the MP and DIY to be worse than the KM84 if that were indeed the case, but I would say they have different use cases.
After removing C2 from my DIY mics, they are a lot closer in sound to my MP SDC-84 mics.
Interesting. I never tested the CM-60 for this before I disassembled them for the project.Electronics are always full of surprises... I would have expected both to have neglible RFI susceptibility. JFETs do not act as AM demodulators like BJT's do. This RFI susceptibility is typical for mics with a BJT output, like the Schoeps. Or even worse, single-ended BJT output designs like Behringer B-5. RFI susceptibility can be reduced significantly with a dedicated filter, like the CM-63 has. The CM-60 doesn't have this filter and is way more sensitive to cell phone interference.
Yep. All connected to the same UA Apollo Twin with the same XLR cables. I had one pf each of the MP and the Takstar KM84 conversion plugged in right next to each other and can watch their levels. When my cell phone gets close, it’s a disaster. Fortunately, if I move my cell phone about a meter away the interference goes away. I just need to be conscious about it when guys in the band come to record that they don’t bring their cell phones into the booth … and that mine is sufficiently far away.Electrolytics are more like inductors at cell phone frequencies and do nothing to suppress RFI interference. But its parasitic inductance, together with other parasitic inductances and capacitances in the circuit, could develop resonant circuits which can raise or attenuate susceptibility at certain frequencies. I have RFI tested several mics between 500 and 1200 MHz and noticed that they differed in the frequency at which maximum sensitivity occurred, probably due to different circuit parasitics. But I did not test a KM84 style circuit. Perhaps I'll do that later. Your observations at least made me curious!
Question: they were connected to the same input on the same preamp or mixing console with the same XLR cable? It could also be the mic input which is AM demodulating the RFI signal. Using my RF jammer I observed different RFI sensitivities of different mixers, so I would not rule it out.
XLR pin 1 should be connected to the body, indeed. If it's not, you'll get zero or little audio signal and loads of hum. The mic tube is the ground return path for the capsule, so it is essential XLR pin 1 and signal ground on the PCB have a low resistance path to the mic tube.One of the things I wondered is whether the body of the mic wasn’t grounded to XLR pin 1 but I used my continuity tester on my DMM and that all checks out as fine.
Right. I thought of that later ... that the capsule wouldn't have had a ground if it wasn't grounded. Good call.XLR pin 1 should be connected to the body, indeed. If it's not, you'll get zero or little audio signal and loads of hum. The mic tube is the ground return path for the capsule, so it is essential XLR pin 1 and signal ground on the PCB have a low resistance path to the mic tube.
For RF, what matters is the impedance ("AC resistance") between pin 1 and the tube. At 800 MHz, a 5mm wire already has an impedance of ~25 Ohm. This is significantly higher than the DC resistance via the XLR screw, which I would estimate is in the 10...500 mOhm range. So every mm of wire counts. Maybe one mic has a much longer path from pin 1 to the mic tube than the other? I'm just guessing.
Takstar understood the importance of the short connection and in the CM-63, they have integrated a spring loaded grounding contact in the XLR. I wish I could find a source to buy these XLRs from. The best alternative I could find on Aliexpress has a metal tab which shorts the tube to pin 1 on two points.
Jan
Hmmm ... I do not think that is quite correct, old man. The set screw works by backing it out against the inside of the screw hole in the handle, and the ground pad merely rests up against the inside wall of the handle - notice the pad is located away from the set screw - making the two somewhat redundant. (Parenthetically, I avoid using ferrite beads as much as possible, preferring to locate the source of the problem and work it out from there. I would probably just move the cell phone to another room ... Different strokes, ya know.). I think I would have to drill a new hole in my mic body to pull that one off. No doubt it’d make the electrical connection to the mic body be a lot stronger.
I’m definitely familiar with the ferrite beads in the shack. 73/KB0YD
