deveng
Does anyone know the size and pitch of the 3 set screws on the MXL 603s body?
I just repaired a Joly modded mic and the set screw slots were all mangled. I had to drill them out to remove and will need to replace with new set screws.
Found a shorted capacitor at the 12v zener. Works fine again.
I hate mechanical stuff! Took me an hour to carefully drill the soft brass set screws out without damaging the body or threads. 20 minutes to find the bad cap. 2 minutes to put a new one in. Now an hour or so to clean out the damaged set screws and probably an hour to find and order the new screws! All the work was in 3 tiny screws!!
regds,
Jeff
regds,
Jeff
