the symptoms you describe match my diagnosis very well, this is not an unknown problem that you describe. I suggest you replace the capsule with another (working capsule) or install a ca. 60pF capacitor as a “dummy capsule”. If the problem is then gone, you know what is going on. An intensive cleaning of the high impedance area with 99% alcohol would also not be wrong, the impurities / moisture are usually not visible to the eye.
Sometimes it also helps to place the microphone in a dry, warm place for a some days...
