My DIY Subkick - soundcloud fixed
Enchilada
Australia
Hey guys,
Thought I might share my subkick I put together for peanuts. The most expensive thing was the speaker. I actually shelled out a little there and spend $40 on an 8" woofer. I connected three resistors to attenuate the output, a 100ohm across the speaker and a 1Kohm on both wires (+ and - unbalanced). Connected those wires to an unbalanced 1/4 inch jack and straight into my preamp.
Below is a link to some photos and an mp3 sample. The first half is without the subkick and the second half is with the subkick. I'm really happy with it  ;D.
http://photobucket.com/enchiladasubkick
http://soundcloud.com/kris-osullivan/subkick-test soundcloud fixed
Your description says A, but B it should be. Standard 20dB U pad.
    81.9 KB
:D it is one of the most original solutions I've seen :D
Initially I thought that the yellow box was the basket of a washing machine :)
Unfortunately the audio in the SoundCloud link there is not. It tells that the page there is not :)
Anyhow I'm really curious to listen to it
You are correct, I have wired it as in A, not B. I wouldn't have thought it would make a difference. It works just fine and the signal is about on par with my kick microphone. I might de-solder the resistor from the speaker and then solder it to the jack input and see if it makes any difference.
I'm looking at soundcloud now to try and fix the problem. It says there was a problem transcoding.
It may or may not, depending on your mic pre, the position of the mic, the way the drummer plays,... It will make a difference of level, that's for sure.
Fine.
yes; experimentation is everything.
Enchilada said:
Anyone had a listen? Any thoughts?
It works very fine :)
What I hear is well defined and if it's possible to attenuate the little "boxy" tail of the sound, I think I hear, it will be excellent
Listening to the sub kick on it's own I wouldn't have said it's boxy sounding. I did compress it though so that would bring out some of the sustain and that could be the tail that you can hear. There's also compression on the mix. If I shortened the release that would reel in the subkick a little. I also wouldn't mix it that loud usually, just wanted to really show what it sounds like  :)
The tail is "boxed" indeed.  I don't give the resposnibility to the cormpression for that. I jsut expressed what I heard :)
I'm pritty sure that if you produce some record, no one will listen to the little "boxy" ;)
We may differ on what we consider to be boxy, I generally think of tone as boxy if the mids are particularly pronounced.
Right. Indeed it's different than my interpretation. I define "boxy" when in the range of the mid tone, I hear like a little "environment" and in al the other frequency range not.
