northsiderap
I am doing a simple transformer isolated 2-stage mic preamp using a 7247 and a 12AU7.
This is my first tube project, so I have a question or two before I finish the wiring.
I have 6.3V AC available. How do I wire up the heaters? In through the C.T. and the 'H' connection to ground? I really don't know what 'series' and 'parallel' really mean for heaters. Do these terms refer to more than one tube in series or parallel, or do they refer to the way you use the heater center tap?
2) How does one determine the resistor value from the filament supply to ground in the PSU? Why is this thing there anyway?
Someone better explain it before I guess and make a fool of myself.
Parodon my newbness when it comes to tubes, and thanks.
