Potato Cakes
Hello, everyone,
For about a year now I have been working on a project that integrates what is essentially a 1073 with additional BA283AV cards, IC differential amps, and a headphone amp. I have written about it here, mostly asking for power supply advice. I thought I had everything thing sorted but now I have a new issue where the ICs (both in the headphone amp and the differential amps) are generating what I can only describe as the sound of the inside of a commercial airliner in flight bandpassed between 1kHz and 3kHz. It isn't pink/white noise nor is it a high noise floor. I've never heard this sound before when working on electronics. When signal is run through the unit there is plenty of headroom and everything sounds as it should, and the mystery noise disappears (perceivably) and then comes back when the inputted signal is stopped. I am using SMPS's (supposedly medical grade), one for the 1073 circuit and one for the ICs. I have exhausted the combinations of who is powering what and how, but I cannot seem to get the noise to go away. I have an earlier version prototype that doesn't have a headphone amp but is powered with the same kind of SMPS and does not have this issue.
On a side note both units are using the same PCBs, but the one without the headphone amp uses a 3x24 gain switch and the other uses a 3x12. The one without the headphone amp buzzes if 0V is connected to ground and the other buzzes without. Both are using the same audio transformers. So I'm fighting not only the PSU/noise issue but also trying to figure out why the grounding is the opposite.
The worst part is that I did have this all sorted, no mystery noise, no buzz, and great sounding audio, but when I put the lid on it and attempted to put it use the noise returned and I haven't been able make it quiet again. This was probably too long winded of an explanation, but my question is has anyone else experienced this type of noise with ICs? If so, what seemed to be culprit?
Paul
Paul
