midwayfair
I've got a modified Hamptone circuit that I have several channels of, and one of them is giving me some constant static in certain gain settings. The static is VERY loud -- around around -35dB at its loudest, so the channel's unusable.
The schematic below is modular, but it's the version with a volume pot (the 10K "Gain" pot hanging off the tail of Q2), transistors are all as shown (2N4401 in Q2) and it's running on 48V.
https://www.dropbox.com/s/lh6g08ayc4ygpxu/FET mic preamp.png
I've got two channels built identically to this one, and one that's identical except with a silicon transistor in Q3 instead of a second FET, but this is the only one with static. They all crackle when I turn the volume (completely expected) of course, because the wiper's changing DC.
The circuit does NOT exhibit static when the gain knob is maxed out, nor when the gain knob is backed off a couple detents from max. The static does get quieter when I turn the gain knob down, but it's actually loudest when the knob is around the center of its travel
If I take a big capacitor and silence various parts of the circuit, the first place the static goes away is the wiper of the gain pot. (NOT the emitter of Q2!)
If I pull Q2, the static goes away, so it's not coming from Q3 or later. I've replaced Q1 and Q2 with no changes. I tried a few different transistors in Q2 with no change.
I thought it might be C3 leaking, so I replaced it, and there was no change. I pulled and checked the filter caps relevant to Q2 and they're all still good.
I suppose, since this is the only channel doing this, that I should just build a new board and replace this one, but I'd really like to get some idea of what could cause this in case it happens again.
