Potato Cakes
Hello, Everyone,
I recently finished successfully building a UA176, then used the knowledge gained from mistakes I had made and implemented them into building what should have been a successful second unit. After chasing down solder joints and hardware possibly shorted things to ground, I still get 2.3VAC between ground and either + or - on the output XLR. There is no voltage between + and - themselves. This voltage translates to buzzing and hum together on the output. I unassembled everything to see when the voltage would go away, but it never did. I now have completely disassembled the wiring from the two main PCB and even pulled the AC hot and neutral going into the unit, but even with just the ground connected while the AC cable is plugged into power I am getting about 0.7VAC between the same pins as before on the output XLR. There are no shorts or measurable resistance between any of the conductors on the AC cable. I am about to start the process of going through all of the parts again to see if anything new reveals itself (this will be my third time doing this process), but I wanted to know is how voltage could be transmitting to ground and increasing as components are being removed? Am I chasing false readings? Compared to the other unit that is working properly, under the same test and power conditions has 0.06VAC between pin + and ground on the output XLR upon power up and 0.02VAC with it powered off but with the AC cable still connected to power. I thought I had the rare occasion of having a bad power transformer, but all of voltages in the unit when assembled are correct and the issue is still present with it fully disconnected. This problem is also the same with all of the tubes disconnected. The 2.3VAC voltage I am getting when completely assembled is immediate upon power up.
I do not intend for this discussion to be how to troubleshoot a 176 but more for a general understanding to be applied to similar situations when building or repairing gear. However, if you do happen to have some insight regarding this circuit and the aforementioned issues I would gladly welcome that information.
Paul
Paul
