With a simple RC, as you have to ADD capacitance to lower the frequency (get flat), the smallest cap value (highest freq) is permanently in circuit -- sitting at the toggle mid (i.e. Off) position. Example:I like the 3pos toggle switch idea!.
Ok...so, the link bus in these racks, as it is a single line, acts as a send from the compressor that acts as the master unit, and as a receiver for the slave unit to be controlled.The rack still needs to be configured to connect the link pins - often a jumper - the stereo link switch simply turns it off/on from the front of the unit.
Yes. But the "47uF" cap is going to be an electrolytic (or it is going to be massive ) and I'd advise that the smaller value implementing the hpf should not be an electrolytic (or tantalum really).A simple RC will be 6 dB/oct while the Sallen-Key is 12dB/oct. Though two RC stages can also be cascaded to give 12dB/oct (the CAPI VP28 does this to get the -6/-12 switch) . You can also use the Neve inductor based HPF for 12 dB/oct.
Prototype to see what you want.
My experience has been that a simple RC filter (-6 dB/oct) is sufficient for the sidechain of a bus compressor.
Typically there is a capacitor at the input of the detector. Usually it is large (47uF) to pass all frequencies. Changing that to a smaller size, will create the HPF. The 3dB corner frequency for a RC HPF is 1/ (2*PI*R*C). Since two capacitors in parallel add, you can use the switch to put a large capacitor in parallel with the small one to go from "HPF on" back to the "HPF off".
