jandoste said:
Hey Guys,
I got a original UA 1176 and since yesterday it doesn't work
I'm trying to find the problem but I can't... it doesn't see any signal and I didn't find any 1176 B serie schematic... Did you have this problem? and what can I do to find this problem? maybe I need to change Attenuator [ in ]? if I get it from Hairball that can I use it?
Thanks for any advice...
cheers
Not much info to help out, beside saying it's not working anymore?
Don't change something before beeing sure it's faulty, you can check the attenuator with your Ohm meter.
What happened before it's not working? When did it stop? Did it stop working when powering on the day after it was working good?
Did you move the unit before? etc...etc...
Since it's a 1176, most problems and troublshooting could be made going with all the infos on the support threads...
Basic check would be, Power and if all is good, but since you say it doesn't pass audio i believe it powers up.
But i would still check that...
Second, any visual check? Is there some bad looking parts? Burned etc...?
Bad transistor maybe? a cold joint on the Audio XLR's? etc.. etc...
Trooblshooting is actually harder than assembly, and sometimes can lead to even more troubles, believe me, especially on old units...
Like moving things around, and those old cables don't like it at all, they get cut, and you put back all things, and it's worst etc etc etc...
turn around an hour, and spot that it's that freakin cable, and you get back to were you were, in one word FUN
An oscillo would be great to spot where your signal gets lost, as always...
But just a DMM can do, but need to know what's going on first :/...
Anyway i'm not a pro in that domain....but i think there is loads of infos here for you to find out where it comes
from, you need to be methodic, patient, and aware of what you're checking and doing, if you go blindly
you'll get lost and won't find your way out, write down what you've done for keeping track of what's been checked etc....
Some basic electronic knowledge is always welcome when trying to fix things...
Good Luck!
