Need help: Meter not working properly
weiss
Germany
Hey guys, there is some help needed on my new gear. I bought the 1176 from hairballaudio (http://www.hairballaudio.com/shop/product_info.php?cPath=22&products_id=143). So far everything works fine except the meter, which won't move at all.
Meter reacts to Signal added directly to the connectors but when i send a 1kHz signal through the input to calibrate my device the meter won't make a single move. Even after turning any calibration trim pots. All wires have been soldered clean and correct. Any ideas what could cause this error?
weiss
Is this an AC/audio meter or does it rely on diodes on the board?
Does the needle jiggle when you shake the meter?
A link to the kit information could be useful?
Don't know, it is connected to the pcb (meter board on the right)
http://www.hairballaudio.com/shop/product_info.php?cPath=25&products_id=40
Sure, no hardware issue.
