Discrete semiconductors and passive components have well known behaviors in circuit. Voltage drops across semiconductor junctions can suggest whether devices are possibly faulty. Ohms law will suggest appropriate voltages across resistors in circuit.I guess based on this, it could be the JFET since I'm not getting enough VAC out of the source and drain but I've tried an LSK170 in the circuit and used multiple 2sk209s... I ordered some J113s from mouser for 1-day delivery yesterday, but I feel like this circuit should work with a 2SK209 based on the specs sheets.
Tried resoldering and nothing. I am getting DC signal through the resistor and the DC values are correct but the AC kinda just turns to 0 after the resistor which I don't see how that makes any sense.Add flux, or feed in fresh solder when the joint is molten (as opposed to applying solder to your iron tip, and the flux burns off by the time you reach the solder joint).
Ok, so I did the calculation (with the help of simulations), and I'm getting everything where it should be right up until after the 10K resistors where the DC values are correct, but the AC value with a .1v ac signal @ 1k injected at the capsule just turns to 0.Discrete semiconductors and passive components have well known behaviors in circuit. Voltage drops across semiconductor junctions can suggest whether devices are possibly faulty. Ohms law will suggest appropriate voltages across resistors in circuit.
This knowledge is not only useful for troubleshooting, but also for design.
Yeah, you were right. Fortunately I am now getting the correct VDC at the collector and the correct VAC at the base but no output on the emitter... I gotta diagnose that when I get back home from work though. Probably a short somewhere. But thanks very much for everyones help.Ah, so it was Q1/Q2 bases shorted together
I suppose the moral of the tale is to actually measure it rather than just looking.
A useful method when troubleshooting a circuit is to measure node voltages with a VOM
Actually, does anyone know what could cause the emitter and collector to short?
Ah, I'll probably incorporate this. I might've wired something weird while messing around with the circuit and fried the transistor at some point...On one hand, 2N5087's are rated for 50v Vce; preeeeeetty marginal if you ask me, for 48v phantom power.
On the other hand, the original Schoeps circuit has antiparallel 6.2v zener diodes (D3 & D4) across the two PNP output transistors, precisely in order to clamp the max voltage present across those transistors.
https://groupdiy.com/threads/schoeps-cmc5-inductor-values.73321/
Shouldn't be a problem using the same 12v zeners you use for powering the JFET (no need to source another part / the zener voltage isn't that critical).
On the other-other hand, i guess there's always the possibility of static electricity zapping some silicon junctions, but... to my knowledge, I don't think i managed to do that (especially on something as insensitive as bipolar transistors) in my 20-odd years of dicking around with electronics. YMMV though...
that is a common fault mode in power transistors where over voltage causes punch through shorting collector to emitter.Actually, does anyone know what could cause the emitter and collector to short? Even after removing it from the circuit, there was continuity in between the collector and emitter pins.
