Two transistors per input, no way is it going to have +4dBm into a load. Another stage for sure.ok thanks!!!
this circuit can drive directly an output transformer or I need another stage to drive it?
[I have hand drawn schematics somewhere] -- Should you believe that your hand-drawn schematics are truly accurate in their representation and are clear enough to be easily read and interpreted when viewed, then send me a clear copy of what you have and any other associated and/or related material and I will go ahead and create a set of CAD-generated schematic copies of your schematic information so others can use them as needed. Sound like a plan???I have that mixer. I have hand drawn schematics somewhere, I can check them out if you need more info. Gain pot is 22k on mine and there is a line amp card to drive the transformers.
No, it is a (germanium) diode and the twirly leads are made that the diode doesn't get damaged during soldering....... There is a unknown component (black with twirly leads... a thermistor?), ....
