substitute
Hello, I'm refurbishing an ampex 601 for stand alone use as a mic preamp. So far I have it recapped and running nicely, I'd like to add phantom power. I'm tapping off the B+ high voltage rail just after the 4.7k resistor after the choke. So far I've tried two approaches...
1) From the above mentioned node, to a 1m trimmer wired as a voltage divider. I dialed down the voltage to around 60v, then connected it to a TL783 high voltage regulator. The first thing I noticed was that once the VR circuit was connected the voltage coming off the wiper of my 1m trimmer dropped down to just a few volts. By going back and forth between the 1m trimmer and the 10k trimmer in the VR circuit I was able to get to 48v, but it's pretty unstable. I let it sit for about a half hour, checked it again and it had dropped down to about 4 volts. I did check the voltage at the node on the power supply and it was still at 340v
2) Strapped a 24v zener from that same node to ground. 4.7k resistor started to burn up.
Does any one have any tried and true methods for safely pulling 48v out of a tube amp power supply?
http://www.ti.com/lit/ds/symlink/tl783.pdf
