separateness
Member
Fellows,
Are there compressors that work by varying the amount of negative feedback fed back into the input?
A rudimentary mockup of the sort of thing I mean:
Ignore the values for now, I just wanted to indicate the basic topology I am describing. I am not very well versed in compressors but most I have thus far seen seem to either vary a bias point or shunt signal to ground.
If there are no such compressors, is there some obvious reason this should not work or is not used?
Thank you.
Thank you.
