gareth33
Hi everyone
I’m currently wiring up the studio with everything on TT patchbay.
We have a Series 1 with unbalanced direct outs and line inputs on each channel.
I’ve been thinking about how to wire the connections, I have a bunch of TRS jacks I’d like to use (don’t have enough TS jacks) so if I go two conductor wires plus shield from the TT bay to TRS at the Neotek end, and wire tip hot, ring empty, and tie the drain wire and negative conductor on the sleeve, is this ok and going to work?
I also wondered whether I need to leave the shield floating at the TT patchbay end.
I have signal going both ways for inputs and outputs.
Thanks for any advice in advance
