colonel_sanders
Active member
- Joined
- May 24, 2010
- Messages
- 43
Hi guys,
I'm bit of a theory newb, so please bare with me. I have a Neumann M-147 microphone which I dislike the sound of. Selling it is not an option at the moment, but I was wondering if I could pull the old PCB and change the circuit, utilising the existing power supply (or with minimal mods) to change the sound to something more usable.
This is the only info I was able to gather from searches...
Capsule: K47
http://www.neumann.com/?lang=en&id=current_microphones&cid=m147_data
http://recordinghacks.com/microphones/Neumann/M-147
The mic body is quite small compared to something like a U47/67. I also have 2 tubes compatible with the MXL 2001 'royer mod' circuit sitting around the workshop (bedroom
If any one can point me in the right direction, much appreciated!
Arie.
Capsule: K47
The K47 has dual diaphragms, but the rear diaphragm is not wired into the mic circuitry. The mic has a fixed Cardioid pickup pattern.
The tube in the amplifier circuit is used for impedance conversion. According to SoundOnSound, it is soldered to the circuit board.
The mic’s output is transformerless, which helps keep the mic’s self-noise to a very low 12dBA.
The manual for the M147 gives the pinout info as follows...
Pin1 -70V
Pin2 +5V
Pin3 audio signal +phase
Pin4 +70V
Pin5 sensor line
Pin6 +32V
Pin8 audio signal -phase
Arie.
