Hello everyone,
some time ago I bought a Neumann W444stb to make a preamp for my Telefunken M15 which has no input or output adjustments and this module was simple and clear to use.
Then since it doesn't have any VU meter I bought two W544s which have a nice LED scale thinking to use those but not finding the diagram anywhere they remained there waiting.
Thanks to you I finally found the diagram but the problem has become even bigger.
Now I ask you, what chance do I have of being able to use it as a preamplifier with VUs operating outside the desk for which it was designed? The power supplies are not a problem but the LED scale seems to take signals from outside, which is not easy for me to understand if perhaps by making bridges between the two connectors it is possible to make it work.
There's a lot of stuff inside those modules but the minimum that works would be enough for me
Many Thanks
Many Thanks
