Hi All
I'm building a 24 bus summing amp around a neumann OSVD line amplifier. I have attached a picture of the module. It is impossible to find technical specs for the cards and even the nice people at Neumann could'nt help with schematics ect. I have found out that it runs on +15/-15 V, which is different for most neumann cards running on 24 V
I have been tracing the card for pin out configuration and it seems that the In+ of the OA10 opamp is tied directly to ground -which makes the input unbalanced?
If so, i want to add a couple of line transformers after the passive resistor(5k1 ohm) network going into the board. I have a couple of cool Jørgen Schou(from a vintage danish broadcasting console) line input transformers rated at 5k:5k or 20k:5k.
Can i just add these in between to make the input balanced? Anything i need to consider regarding input/output impedances?
thanks in advance![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Lauritz
thanks in advance
Lauritz
