Neutrik Macro Object in Front Panel Express?
clister01
Los Angeles
I know it's been discussed before but has anyone used one of the built in macro objects in front panel express to make cutouts for the Neutrik D series XLR connectors? And if so, which one worked?
Or does anyone have a front panel file with the connector hole and mounting screw holes that I could grab?
I've been using a green lee punch for a while but I never seem to get the xlr jacks mounted straight using that method.
Thanks for any help!
-Cameron
yes, i made a frontpannel for a tube mic psu which uses xlr -d series.
the macro xlr 24mm x = 9,5 y = 12 is the right one for the d-series. i took the macro witrh the threads, works perfectly.
-max
