nielsk
I just want to see the 33609 rev "A" schematic and compare. I have the full 2264 and 33609J doc packages, and as far as I can tell the 33609 is an evolution of the 2264 with very few circuit changes.
gemini86 said:Joke aside though, why tell everyone you have a secret, when you intend to keep it a secret? This is playground type stuff.
nielsk said:and as far as I can tell the 33609 is an evolution of the 2264 with very few circuit changes.
As far as being close to the original, neither of my units were.
andre tchmil said:Biasrocks said:Yes and yes.
My extensive research when I built my 33609 did result in a shockingly better sounding compressor.
It actually made Igor's original sound like a plugin version.
This knowledge was hard earned and I feel somewhat uncompelled to give it out freely.
A close look at the schematics for both compressors will begin to reveal some, not all of the details.
For instance, there's a huge hole in the Igor's 2254 sidechain design.
I would recommend building the 33609 over the 2254 I think you'll get more use out of it and it'll be the closest you get to the real deal.
Mark
If you used Igor's PCB's for your testing and improving, stop nagging and thank him instead for releasing the PCB's , cause nobody else did it before.
If you feel the need for improving the unit , go ahead. I'm sure plenty of people are happy how it sounds now.
Igor said:In any case, Mark, may I ask which PCB's did you used?
