I already know the answer is "try it and see" but thought Id pose this for the experts.
Im building a 5x2 mixer out of 33114 EQs. Starting to think about the make up amps on a passive mix bus. I was going to use 3415's for this but am considering something different. First off, Id like to see if the make up amps could be transformerless inputs. Second, Id like to see if I can basically copy the block of the 3415 but instead of using 438's on the input use a 440 instead. Ideally, Id like to have the mix buss feeding 2 440's in series into an output transformer. Im thinking of using 440's simply because I have a few extra, no other reason.
Is there an obvious reason why this WOULDNT work on paper?
also, can a 440 drive an output transformer wired 50 ohm primary 600 ohm secondary into 600 ohms?
thanks!!
dave
thanks!!
dave
