Neve BA283AV -18 pin amphenol wiring?
dukasound
Kotor, Montenegro
Does anyone can send me pics or layout of original wiring on 18 pins amphenol socket for BA283AV and connections to other part of 1272 or 1073 circuit.
I can wired from documentation but I need original.
Thanks in advance
Duka
http://members.nuvox.net/~zt.robgrow/circuits/neve/neveba283.html
and page down
[quote author="uk03878"]http://members.nuvox.net/~zt.robgrow/circuits/neve/neveba283.html
and page down[/quote]
Thanks for reply
I pick a tone docs of this last year. I can do it from doc. but I need pics or layout.
Exaple, where connect on socket resistors, caps does it used free connectors etc. Also where are 12 and 270 ohm, 470 and 1000uF from 24V supply.
Duka
do you mean like this?
http://www.wagrecords.net/PDF%27s/BA283AV.pdf
http://www.wagrecords.net/neve.htm
[quote author="uk03878"]do you mean like this?
http://www.wagrecords.net/neve.htm[/quote]
Probably my english is very bad (not the first time). I have all of that but I havent excatly layout. I never see original Neve and I dont know connections behind 18 pin socket
Thank
Duka
[quote author="peter purpose"]http://www.purpose.freeserve.co.uk/1073schem.jpg[/quote]
Again my english :? .
I have all of this files.
Duka
[quote author="rlaury"]I think we're asking for a pictorial of the the
actual connector. Or how to mount the components.
RonL[/quote]
I wanna build one clone and I need to know original layout and wiring. What parts are where (on Ba283 socket , on transformers, on back socket on chassis etc)
Duka
I mean connections like this :cool:
Why don't you use the PCB from vintagedesign
http://www.vintagedesign.se/diy/1290pcb.pdf
Then you don't need to go into these considerations at all, because all resistors (beside the potentioneter) between the various amplification stages are already on the board.
I'm about to finish the Neve1290 based on the pcb from vintagedesign using Joe Malones schematic for a two gang switch from Rob Grow's homepage. So far everything is working as expected and I just ordered some Lundahl transformers to finish the project. I intend to use Kevin's suggestion from the old forum about having a switch to control the gain of the first preamp stage.
Good luck with building the Neve clone.
Klaus Mogensen
[quote author="Klaus Mogensen"]Why don't you use the PCB from vintagedesign
Klaus Mogensen[/quote]
I started before one year 1290. Thomas is my friend and he send me some perts.
Need only one output transformer and chassis and I ll finish.
I would like to build original original pcb (1272 version)
Best
Duka
O.K., then I understand.
I hope to finish mine during the christmas holidays. I haven't passed audio through yet, but only checked it with a signal generator and an oscilloscope. I intend to include a transformerless DI based on Bo Hansen's circuit.
I'll post some picture when it is done.
Best, Klaus
Hey there Duka,
Sorry to come in late on this, too much stuff going on.
The stuff I dug up on the 283 as connectivity came from the jlmaudio site, he's a couple of pdfs that show how this module can easily be hooked up.
You may have seen these already, but.....
http://www.jlmaudio.com/JLM1272simplemod.pdf
http://www.jlmaudio.com/JLM1272hotrodmod.pdf
Regards
ju
[quote author="fum"]Hey there Duka,
Regards
ju[/quote]
Hi JU
Thanks for link. I have it. I dont want to make mods, I only wanna know where Neve put supply resistors and caps (12 and 270ohm and caps 400u and 1000uF) 1,5K and 100uF and how they wired BA283 socket with back socket.
Duka
