I built this preamp in 2014 or so and enjoy it. I put an 1176 (just the unbalanced middle section of the compressor - no transformers) in the middle of the Neve circuit and it works well for tracking. BUT... I am finding I'd like to Hi Pass most sources before they hit the 1176 compressor.
So that means I either need to add a simple HPF switch somewhere in the circuit or build the actual 1073 EQ. I doubt I'll ever use most of the Neve EQ features other than the HPF. If I could just add a toggle switch to roll off below 100Hz or 150Hz I'd be plenty happy with that.
So two questions:
1. Is there a place to find a board for the 1073 EQ (only)?
2. Alternatively, where would be a suggested place to thin this thing out if I were to simply use a smaller bypass cap to couple between one of the first couple transistor stages? I'm thinking the tantalum cap circled. This thing must pass just about everything going through it at 10uF. Maybe something more like 0.22uF, 0.47uF, 1uF, 5uF, 10uF on a rotary 5 way switch would be a good way to HPF this thing?
So two questions:
