Interesting they quote distortion at 100Hz which is not surprising because at higher frequencies the flux density will be much lower so there will be much less distortion.
hello, do you have the drawing pertaining to this page? I can not enter because it appears that the domain is nonexistent.
thank you, that pdf is a very great help. It's exactly what I was looking for!See the way back machine. Use the link from the first post… or check this out. Works on my iPhone.
schematics are copyrighted art - your version is new art - circle C that stuff with your name or groupdiy and the year.Circuits can't be copyright.
Circuit drawings are always copyright.
A mechanical copy (Xerox) is infringment.
A re-draw is a New Work and has its own copyright, not infringing.
Circuit details may be under Patent. You can re-draw these. You may not assemble the circuit without patent infringement; however broad leeway exists for "study and experimentation", so you typically don't get in trouble until you make a lot for sale. (Maybe if you gave them away in vast quantity.)
I am not a lawyer. Don't trust any legal opinion you haven't paid dearly for, from an expert who has also sized-up the other side. Even if you are right, if the other side is rich, they win.
Just an edcated guess: if the xfmr was gapped the effect of DC in it would be negligible. Since users want to hear evidence of the effect, I would say it's ungapped.Does anyone have any guesses if the output transformer would be gapped to handle the silk DC offset better? Or is the offset small enough to not cause flux density issues?
Not really. C49 & C54 load the Common-Mode choke, which results in some ultrasonic resonance, that must be tamed with this RC series circuit: it's called a Zobel. The value of these two components is dependant on the characteristics of the CM choke. We don't have enough info to calculate their value.Does anyone have a guess what the value of the cap that is in series with the 560 ohm resistor across the inputs is? I am assuming this is some kind of high frequency filter for EMI rejection?
Probably.So something like a couple hundred pF
Not related to cut-off. Cut-off is more dependant on C48 & C54.for a cutoff frequency in the 100s of khz ?
I only see two 68k resistors in the base to gnd of the transistors...
That's not what I see hereI have another question about this preamp circuit.
I noticed that the output gain trim is based on a variable gain balanced input amplifier, with the output of the potentiometer/opamp arm, tied back to the NON INVERTING input. I have seen a simmilar circuit in the Douglas self book "Small signal audio design". The difference is that the Self circuit, ties the feedback /potentiometer arm back to the INVERTING input. My question is if there is really a difference, in practice, or both versions behave simmilar?
Late to chime in, but Ian is correct about schematics. The copywrite on a schematic is only good for that "art" You can redraw it, and publish it any way you choose; just not the copywrited version - slap a "circle C' on your art and its relatively protected. "Circle R" is registered trademark - meaning someone spent money to actually register the art.It is perfectly legal. The device is on sale so anything in it is public domain unless protected by patent or registered design. A hand drawn schematic derived from the product itself is quite legal.
