ruffrecords said:Assuming these are balanced, then the rule is connect the shield to the chassis right at the connector. Connect signal 0V to the chassis at one point only.
inputhone said:with 0V i assume he actually means your 0V rail within the DC circuit, that should be connected to chassis always jsut at one point only.
ksor said:inputhone said:with 0V i assume he actually means your 0V rail within the DC circuit, that should be connected to chassis always jsut at one point only.
When I'm just "moving" the balanced I/O's from the rear panal to a new extra front panel there is no DC invalved at all - I'm just "repeating" the I/O-female-jacks in this extra new panel.
inputhone said:ksor said:inputhone said:with 0V i assume he actually means your 0V rail within the DC circuit, that should be connected to chassis always jsut at one point only.
then just ground each jack right at the chassis itslef, and you should be good..
