G
Guest
Guest
Hi folks,
This is a general theory type question, I guess.
Looking at the power schematic for a seventh circle n72, the phantom confuses me. But, that's because ALL phantom confuses me (see signature below).
I the schematic, there are 48v coming off the ps. The 48 then hits a resistor (150 ohm), and is then wired in parallel with two capacitors. The first is polarized (positive terminal to +48), the second not polarized. Then, the positive output is split down the two signature 6k65 resistors.
I guess I'm wondering the following question:
Are positive polarized caps always connected to positive charged voltage? If so, is there a simple reason for this?
Why are the resistors and caps even there? To smooth any intermittent power issues on the 48? This seems redundant; the 48 is already regulated in the power supply.
Kelly
Kelly
