This is a 5F1 champ I've built. I already got it working, but then I decided to clean up wiring, change grounding etc...
And now it doesn't work anymore.... all I get is a quite hum. :-\
It must have something with the first stage not pulling any current. I get no voltage drop on the bias and plate resistors. The other stages have correct bias voltages.
The things I already did:
- I tried different tubes.
- I replaced the tube socket (one of the terminals was messed up anyway).
- continuity meter shows no problems in the preamp area.
- I resoldered all the relevant joints, just to be sure.
- the bias resistor is grounded by a thick copper wire to the chassis.
- I tried disconnecting the bypass cap (in case it leaks).
Not sure what else I can do... any suggestions?
P.S.: I built the cabinet from scratch 8)
![IMG_1519.jpg](https://proxy.imagearchive.com/7ab/7ab9d96278da0ba342de37dc45863897.jpg)
