Last night I started to recap the busses in my PM2000. I am only trying to replace the electrolytics in each of the eight bus channels. I recapped 2 channels which was a piece of cake. When I put them in the console I discovered that there is a low level hum and a bunch of noise on both of the recapped strips. The noise kind of has a fast ticking to it. The channels pass audio and the audio itself sounds good. There is an extension in the high frequency compared to the bus channels with the old caps. The noise is not that loud compared to the audio going through it, but it is slightly audible under the audio and this kind of noise is completely absent from the other busses with the old caps. I am a bit confused here. The replacement caps are all the same values as the originals, except a few are rated for higher voltage. The caps are all smaller than the originals in physical size but other than that my understanding is that they should be the same thing. I have never worked with bipolar electrolytics before, but my understanding is that they can be placed either way in the circuit. There are eight caps on each bus channel strip. Here's the cap compliment in each channel and what I used as a replacement:
Bipolar Electrolytic (Panasonic SU for replacement)
100uf 25v x2 replaced with ECE-A1EN101U
3.3uf 25v x2 replaced with ECE-A1EN3R3U
47uf - 16v x1 replaced with ECE-A1EN470U
Electrolytic (Panasonic FC for replacement)
220uf 25v x4 replaced with EEU-FC1V221
This seems like such a simple job so I am really confused as to what could be going on. If you wise folks have any ideas as to what could be going on I would greatly appreciate it. I am attaching the schematic of the channels for reference.
