leswatts
They are pretty small...fraction of a mm. Most used is probably the Knowles units. Condenser with 4 micron diaphragm/backplate spacing and 11 volt polarization. I extrapolate the self noise at 40-50 dba... pretty bad. But typical of mems. They also have a 20+db peak between 10k and 20kHz.MEMS is micro-silicon, right? So the largest structure is about as small as I can see. My naive thought is that this is too small to approximate human hearing without some significant re-writing of laws of nature.
I don't think you'll see these as studio mics. The noise sources are mostly force noise and head amp noise, and I don't see how that could be improved much. All you can do really is limit the bandwidth.
It would take about 60 of them in parallel to get reasonable noise performance, but they overload at a little over 105 db spl...so it would still be a poor performer.
However they have sold nearly a billion of them since '03. While initially more expensive, they can be pick and place mounted before solder reflow which apparently is a cost saving.
Les
L M Watts Technology
