Noise from 48V in THAT1512 preamp
SirEgno
Member
Italy
Hi all,
I made a very nice preamp using THAT 1512/1646 chips. The schematic is the standard one with minor changes. I gave it to a friend and he's using in his studio recording great musicians.
BUT... another friend is experiencing some noises with 48V. The noise appear only with some microphones (e.g. neumann u87) or without any mic plugged.
The power supply use an external transformer (2x18/2x650mA), 7815/7915 for the chips and the schematic taken from the G9 for the 48V. I modified the schematic by making it doubler and not tripler and replaced the trimmer with two 24v zener in series.
Simulating in LT Spice the 48V should be perfect, but in real life it produces some noises. The noise is like pops and cracks, not hiss or hum (I attached a sample whitout mic plugged, I don't have a u87, and 70dB gain).
I tried also the original G9 schematic, but the noise is the same.
I don't know what to do or what to check.
Unfortunately I don't have an oscilloscope.
Any idea?
Thanks in advance!
PS. sorry if my english is not ok, I'm italian and so I'm better at eating then learing foreign languages.
  • noise48V.mp3
    465.3 KB
    16.9 KB
Hi Jakob, thanks for answering.
The capacitors are 100uF with positive lead toward the microphone input. I didn't see any schematic with this large capacitors, maybe the problem is over there? I will try to change with a smaller value later.
Due to the fact that the noise appear only with the phantom power engaged I blamed the 48V supply.
I am not familiar with "G9," but that schematic has all of the noise of the Zener diodes applied directly to the base of the capacitance multiplier transistor Q1.
Usually a capacitance multiplier will have the base fed by an RC circuit (that is, a resistor between D5 and C4 to form a low pass filter for the noise).
I Agree with ccaudle above. I would have used an LM317 with the feedback to the base from the output side. that would eliminate R1,2,4, D4,5,6, and C4. I would put a 200 to 250 Ω resistor from the out pin 3 to the Base pin and another resistor from the base to ground the value of which will determine the output voltage. No cap is necessary on pin 2 (Base). This also provides a bleeder path when turned off. A cap can be applied to pin 2 for a turn on/off ramp. The output cap, C5 would best be a WIMA 10µf @ 63 volts multi layer film cap, very low impedance. I might leave the last cap in the Tripler a higher value. A .1µf multi layer ceramic cap on the in and out pins to ground will suppress any oscillations. This approach would also compensate for the load whether you were powering one or ten mic's with this supply.
The LM317 is rated for max 40V. I found the TL783, that could be used in the same way, but with higher voltage.
Am I right?
EDIT: the datasheet says that there is a minimum output current to maintain the regulation. 15mA. I think this is less than the maximum absorbtion when all 4 channels are working.
That means that 40 volts between the input and output voltage the pin 2 voltage voltage will never be more than a few volts different than the output voltage. So say there's 55 volts on the input pin 48 volts on the output pin and 46 volts on pin 2 (adjust pin) there's never more than a 12 volt difference across the any part of the LM317. the current is maintained by the 2 resistors that set the voltage.
My memory, which might be wrong, is telling me that the small-signal voltage noise at the output of an LM317 regulator is lower than that of the 78xx. In many circuits (having large power-supply rejection) this won't matter much but there are circuits that pass on supply noise via biasing networks, etc. and the lower noise would be a benefit.
Also, there is the LM317HV which can handle a higher input voltage.
You don't need additional load for the TL783 with 4k7/2W resistor as shown in schematic by Ian.
    11.6 KB
