buildafriend
You should try pulling the channel cards. Divide and conquer is the name of the game
Brian Roth said:Looking again at the Elan I/O module schemos, I can now see how a rogue channel could inject noise into a channel of the stereo bus. To try and isolate:
1. Go through each I/O strip and push the "Monitor On" switches to off position while listening to the noise.
2. If No Joy (and with the "Monitor" switches still off) then walk through the modules and press the "Rev" switches.
Bri
pucho812 said:Yes went there the first time I was out looking at the desk. No joy.
Brian Roth said:And you also muted the Echo Returns on the master module? Hmmmm...
bri
What kind of sol is this. Is it solo in place (destructive) where it mutes all the other channels or is there a separate solo bus which feeds separately into the monitor via a relay/FET switch?pucho812 said:yes... I know it's a separate path but if I solo something, no noise.
ruffrecords said:What kind of sol is this. Is it solo in place (destructive) where it mutes all the other channels or is there a separate solo bus which feeds separately into the monitor via a relay/FET switch?
solo each channel one at a time... until you find the unhappy one.pucho812 said:yes... I know it's a separate path but if I solo something, no noise.
JohnRoberts said:solo each channel one at a time... until you find the unhappy one.
If none problem is in L/R bus
A partial short from a bus to ground like from a solder blob or splatter, could cause an elevated noise gain, but they are usually visible.pucho812 said:Well haza haza. After a much back and forth with the manufacturer, mainly me insisting the fault is the motherboard and the manufacturer insisting it was not, they sent out a replacement motherboard.
Took several hours to remove the old motherboard. Unsoldered every wire. Then soldered the same wiring to a new board. Once I did that, everything was working as it should. All the noise and everything went away. Could it have been that I touched up a bad joint? No, I had already went there on the old motherboard. Since the motherboard is traces and a few passive components, I can only assume at this point that a trace cracked with a hairline fracture causing problems. The ribbon cables were reused and ok. No failed passive components, no active components. But anyway is all working 100% now.
So that's how this worked out. I was just as stumped the day we went out and looked at it together, but also came away from that visit thinking that the motherboard had to be defective.Well haza haza. After a much back and forth with the manufacturer, mainly me insisting the fault is the motherboard and the manufacturer insisting it was not, they sent out a replacement motherboard.
Cracked trace perhapsSo that's how this worked out. I was just as stumped the day we went out and looked at it together, but also came away from that visit thinking that the motherboard had to be defective.
