[quote author="Svart"]hmm I've noticed hash on my cards as well.. [/quote]
...step away from the pipe...
:twisted:
I hit it with the big guns. 10µF "killed it to death". Maybe I'll try 1µF, or 0.1 or whatever, but for now I'll just make a mental note to provide for a capacitor across there. If the space is big enough, people can put any value they choose in there between 0.1 ceramic and 10µF electrolytic.
For now, I'm moving on from chasing this issue, as I came across it as a 'kink' in a design/build project that I'm deep into, which has a hard deadline in a few days. -The noise was killing me, since this project most assuredly requires a dynamic range well in excess of 100dB, and half a volt of white noise was starting to find wasy of creeping in in tiny amountsm where it DEFINATELY wasn't welcome!
-It's all good now though! The board may have space for both an electrolytic AND a ceramic, because the electroltic DEFINATELY does improve ripple rejection (during start-up) and gives the rail a pleasant 'soft-start' behaviour, whereas the ceramic will help to do the job of nailing any HF to the floor.[quote="JohnRoberts]When you removed power and unregulated rail decayed, the regulator output pegged full on and was quiet because it was no longer trying to regulate to it's noisy internal reference.[/quote]
Yes, I see that now. There was 8V margin, which decays VERY quickly since it's the first bit to drop off. It gave the illusion of being instantaneous in fact, when under load. -More reservoir would likely have reduced this illusion.
Keith
