rensjepensje
Member
- Joined
- Jan 7, 2015
- Messages
- 12
I'm planning on building a stereo crossfeed module to insert into het cable of my HD600 headphones (inbetween the amp and the headphones).
It's a fairly simple design that I received from Meier designs.
The original version was built with Ohmite thick film TA resistors (5w), but I want to use non-inductive wire wound resistors (this was also an option according to the designer).
The resistance values are 4400 ohms, 2200 ohms, 330 ohms and 50000 ohms.
I'll add the schematic as a reference.
I'm by no means an electrical engineer, I'm restricted to my 'connect-the-dots'-soldering skills.
Who can point me in the right direction as to what brand/type of resistors I'd best use, what power rating and tolerances should I look for and where I can order them (in the EU)?
Hopefully someone can help, it would be greatly appreciated.
Thank you!
Rens
Thank you!
Rens
