taliska
Is there anything to be wary of when purchasing NOS pots? Could the tracks degrade over time?
Kaz
Kaz
JohnRoberts said:If they have been stored in a good environment I would expect them to be OK. Pots generally wear out from use, not degrade due to wiper oxidation from sitting over time, while that could happen in a bad (humid) environment. If you are talking about buying a significant number maybe buy one first and take it apart, I'd look for wiper oxidation or contamination on the resistive element, especially for non-hermetic sealed parts. Sealed parts are probably OK.
For less expensive non-sealed pots, it might be worth sacrificing one to determine the shape the entire lot is in.
thermionic said:The track lubricant in AB 'Mod pots' dries up over time. I've seen this in many examples. If they've been kept in a near-air tight environment they'll probably be ok, but they are very hit and miss in my experience. It's difficult to get new lube in there, although it can be done and makes them work like new. Once the lube's dried up they can feel and sound very scratchy. I've found this issue with different varieties of AB pot. I use ALPS pots that are 30+ yrs old all the time and they work like new.
